J-Owner »
https://forums.nicoclub.com/j-owner-u3840.html
Wed Aug 16, 2006 7:53 am
$5K is high. What you need are maintenance records to tell you the condition of the vehicle. Hopefully the current owner had it serviced at an infiniti dealer in which case you can get a printout of the maintenence records.
I would be concerned that the timing belt, timing belt tensioner, idler pulleys, water pump, etc. were replaced at the proper time (105K miles). If this has not been done then odds are the current seller doesn't care much about maintenence and therefore I would be leary of purchasing the vehicle.
The J30 is the best car I have ever owned. I currently have an '05 G coupe but had a '95 J30t for ten years. The key to these cars is maintenence. If you properly maintain it then It will last you quite a while. If this guy has not properly maintained it and you buy it then you are risking significant costs to yourself in the future. The parts for this car are almost always only available through Nissan and they are not cheap.
If it IS properly maintained with appropriate records and you can get them down on the price then I would say that it sounds like a good buy. I think $3,500 would be a better price. $4K tops.
Just my $0.02
