Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Aug 08, 2008 4:38 am
The O2 is for fine tuning the fuel mixture. It only sends an on/off signal to the ECU in relation to the outgoing exhaust gasses. I can run a car without an O2 sensor, but I can't without a MAF.
The reason the MAF is designed to be upstream of the turbo is due to heat issues. An MAF's job is to measure air volume. By putting the MAF right behind the filter, it can read the air pre-compression and be able to accurately relate the volume of air as it passes through.
MAFs don't have pressure sensors in them (or else they'd be MAPs, not MAFs), so a MAF wouldn't be able to tell the difference between 5 psi and 10 psi. It could just tell you "x" amount of air has passed through because it had to use 'y' voltage to keep its heating element at optimal temperature.
There have been successful blow through MAF setups done on 240s. You should search for them and read up on them on google. I for one, don't like them due to higher failure rate and the ECU has to be programmed for not only injector size and MAF type, but it will have to be tuned to recognize the flow/boost characteristics of your turbo. It's just easier, simpler, and you have longevity on your side if you run the MAF in stock location
