Think it's time to do my pcv system right
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
What do u folks use in your dets as the pc valve? I would be a little surprised if the regular pulsar ca18de one can handle boost? I'm gonna rework the hoses and plumb it into my intake with a catch can like I should have gotten done a long time ago :)
Yeah i found the crossover parts.. but if i lookup Bosch PCV142 it doesnt come up alone.
ALSO i jsut realized autozone lists theirs as PCV1142DL ... so can i really use my factory stock valve and be fine with a catch can setup venting back to after maf/before turbo?
leadpaw
Car: 1985 sentra ca18de
Looks like the CA18dets use the S12 200sx pcv valves. (click on the p/n for interchange)
http://nissan4u.com/parts/200sx/el_s13/ ... ntilation/
Liquid_Neon
Well according to autozone, the 200sx turbo and pulsar nx se use the same pcv1142 valve. I dunno how well it seal cause i can blow through it a teeny bit with my own pathetic lungs.
Trouble is now in finding some adapters to fit the oddly large 19mm bung that sprouts from the spark plug valley, which has the regular 5/8 size on it also. I also will apparently need two T fittings (maybe?) to route the center and exhaust breathers over to my intake pipes. I will prolly just T fit the pcv system into the feed line i use for my iacv system.
TheMAN
don't buy that vatozone JUNK
go to nissan and buy a proper PCV valve... it's all metal and constructed way better... lasts practically a life time
you DO NOT want to tee both valve covers together... that is a BIG NO!!!
please go search and read the posts I made regarding the PCV system and follow it!
Liquid_Neon
What do u mean dont tee the cam covers? Only my exhaust has a breather and the other breather is a block connected to the spark plug valley. In stock trim the block was tied into the pcv valve AND the intake pipe, and the exhaust breather piped into the intake also? Why wouldn't I do it that way?
Also the autozone pcv is metal and seems to be the same build as the one I already had(but I plugged it up long time ago). I can swing by nissan today and see if they stock one, I already asked about stock hoses and they longer carry those :(
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
I was talking to my stepdad the other day about PCV valves because I was worried mine was leaking on my E16 car and that's why I was burning oil. I got another new one and it does the same thing you're talking about, it'll seal one way but the other I can breath through it a little bit. He told me that actually how they work is kinda complicated (simple in design, but complicated in function I guess). A PCV valve is made to circulate, letting the crankcase vent at almost all times. It won't let air backtrack, but it'll vent forward into the intake. The only time it fully seals into the intake is when there is a huge burst of pressure (something our puny lungs can't create), preventing oil from being thrown into the intake.
float_6969
^This^ Your stepdad knows his stuff. Also, I have a metal PCV valve from Advance Auto and it's fine.
TheMAN
Liquid_Neon wrote:What do u mean dont tee the cam covers? Only my exhaust has a breather and the other breather is a block connected to the spark plug valley. In stock trim the block was tied into the pcv valve AND the intake pipe, and the exhaust breather piped into the intake also? Why wouldn't I do it that way?
let me search for you since it seems you didn't, otherwise you'd already understand why the plumbing must remain segregated instead of tied together so that the system works efficiently/properly
real-ca18det-catch-can-popping-dipstick-t557961.html
mdb4879
Are you trying to set up your PCV system like the stock FWD CA16/18DE? I'm just curious because you mention the block in the system in stock trim so I didn't know if you were using FWD cam covers or what.
I don't really want to turn this into another huge debate, especially since I'm a novice on PCV systems and you really seem to know a lot about it, TheMan, but I have to disagree with you on the not teeing the covers together things. Reason being that I recall when I was having trouble understanding how to set up a catch can you pointed out that on most other motors, such as SR's, there is only one valve cover and multiple nipples on it, so rather than thinking of how the CA has an exhaust side and intake side cover, just imagine it were one big cover. That being the case whether you have two hoses go to separate locations in the system or you tee them together is irrelevant because they are essentially tee'd together through the valve cover. I agree the shouldn't just go to a catch can with a breather, but I can only imagine that if you tee them together to go to a single catch can then have either two outlets from the catch can or one outlet that you tee into two hoses again and have them go to their respective areas of the system (one to the PCV valve on the intake and the other to the pre-turbo intake plumbing) then everything should function normally. I can only imagine the reason the lines are separated from the factory is because it resulted in less plumbing and possibly better flow without using huge hoses.
As I mentioned before, the entire ventilation system is connected though the valve cover(s) and crankcase. Any time there is pressure, positive or negative, that pressure is seen through the entire system and creates a flow. Under negative pressure the PCV valve will close and the vacuum in the crankcase will be displaced by the relative positive pressure being fed in through the connection to the suction pipe. Under near zero pressure the crankcase will flow and vent through both the intake manifold via the PCV valve and through the suction pipe. Under positive pressure and extreme bursts the PCV valve will close again (in the opposite direction this time) and the flow will be directed out through the suction pipe where there is a relative negative pressure.
Since everything is connected to the crankcase it doesn't matter where or how many times you connect the two hoses together because collectively the system is one entity and shares a single volume. For all it matters rather than having the hoses imagine it were just one big box with a PCV valve in it a part of the suction pipe in it. The system pressurizes as a whole and flow is created because of the difference in pressure outside of the system.
The only other thing I have to say about teeing the two hoses together is if you do the single hose it become must be able to flow just as well as the two hoses connected to it combined. I would just use the surface area of the inside diameter to determine the size of the new hose. For instance, if you had two hoses each with a 1 inch ID then add those together and the surface area of the ID of the new single hose must equal that. 1^2+1^2 = 1+1 = 2 So the new hose needs to have an inside diameter of the square root of 2, which is 1.41 inches (I disregarded pi because it was a common factor for all the equations and was negligible). Then when you tee the single hose back into two just use the original size hose for each. This may only be useful if you are trying to implement a single catch can tied to both the intake and exhaust cam covers. If you are not using a catch can then I see no need to tie them together because they will only have to be tee'd back into two lines. So with a catch can leaving them separated would be the way to go.
float_6969
The man, I'm not understanding what you're saying about not teeing them together either. If you just mean tee them together and connect nothing else, then yes, you don't want to do that. But other than that situation, there is no issue to tee them together and connect them to the intake manifold with a PCV valve and to the turbo inlet.
TheMAN
exhaust valve cover needs to be an air intake... breather filter or just hose connected to suction pipe
intake valve cover side needs to be connected to the PCV valve
you are free to put in catch cans in line all you want, just don't tie both sides together.... if you want a catch can for both sides, then use 2 catch cans
the system has to be setup that way to effectively balance the pressure in the crank case and rid of the blow by gasses... it is an air exchange system
the thread I linked explains this in greater detail :)
Liquid_Neon
Well i no longer can have a pcv valve.. it stripped. oh well. I hooked my lines to my intake and everythings been going fine. You seem to be missing the part where my ca18 DOES NOT have a breather on the intake cam cover, theman :)
my fwd factory setup looks like this:
So as u can see, both pcv tubes go right into the intake pipe. since i cant plug the one into my pcv valve right now, my setup is jus linked to the pre-turbo pipes. Later on i will see about welding/repairing the spot for my valve and it'll be perfect.
TheMAN
sorry, I missed the fact that you have a FWD CA.... I'm so used to RWD setups :blush:
I would imagine that T block that bolts to the spark plug channel has a divider inside that separates the breather and suction side.... in any case, as long as you keep what's going in and out separated (don't tee both hoses together), you should be fine
