MinisterofDOOM wrote:Oh, let me see now. What have I been saying for YEARS NOW?
Exactly. Lots of gears can achieve low cruise RPM in smaller motors, but it's when you've got the torque on tap that it really becomes beneficial. An example is the Chrysler Pentastar V6 that was in my rental minivan last summer. It spun at a miserly 2000 RPM at 80mph. But the lightest touch of the throttle or the tiniest incline led to a downshift (or, more often, two), because the engine simply doesn't have the torque to DO anything with 2000 RPM. But I can put the LS in 5th gear at 10mph and never think about shifting again. 220 ft-lb from 2000 RPM means I don't even have to downshift to PASS at highway speeds. There's no need to EVER exceed 3k RPM, even when not driving conservatively. And the AJ35 is gutless and inefficient by modern standards.AZhitman wrote:Plenty of torque and HP means the engine isn't working hard at all, and in 6th gear, it's basically just an air pump, since fuel consumption is minimal.
Nobody makes a car that can do optional drive, the mechanics of it are just too expensive, complicated and pointless. Having a turbo on the gas/diesel engine would also be pointless in an electric drive setup unless the vehicle was very very heavy.gwoods wrote:I think turbo's have a place in the future of cars. A turbo diesel hybrid sounds nice. Imagine it being a plug in where you can use a dash board dial to choose what the gas engine does. When you are crawling through rush hour with a fully charged battery you leave the diesel off. For longer trips you can dial in generator and the diesel will come on to charge the batteries and extend the range. For performace the diesel can drive say the front wheels? Electric motors drive the rear? Giving you AWD in performance mode.
Actually, Nissan and Honda have both done this. Nissan with an older Cube model and Honda with the new RLX. Both cars use a traditional FWD setup but add electric motors to drive the rear wheels. As I understand it, the Cube used this format specifically because our is LESS expensive than a "traditional" hybrid setup, since you're not changing anything with the primary powertrain.Dattebayo wrote:
Maybe you're not aware of it, but most of our trains have been using the current system of hybrid operation for many many years now...
Actually thats what they're doing with the NSX nowRazi wrote:
You guys reminded me of the Honda Dualnote concept from 2001. It had a V6 in the back, and 2 electric motors in the front. Pretty cool.
Looked funny though.
THIS.float_6969 wrote:Only they need to stop being dumbasses about it and design the ICE to run VERY efficiently at a single speed.
Would rather see in-line 6 engines.... V layout is just okay.AZhitman wrote:Interesting results from some pretty common testing.
In the race for more performance and higher fuel economy, larger naturally-aspirated engines still hold an advantage.
http://www.reuters.com/article/2013/02/ ... 1D20130205
Maybe put all that R & D money into building more efficient V6 engines?
I've been saying this for a long time...Automakers should focus on: Reducing friction, adding direct injection, reducing overall weight, improving aerodynamics.
What do you think this will mean for manufacturers?
The natural gas doesn't power the vehicle. Because of this, you can design an engine to run at a single speed. This allows you to design a lighter, compact engine with high output and better fuel economy. In theory, this would negate the drawbacks of natural gas fuel.asoomal wrote:Except you get no range out of a natural gas vehicle -_-.
Not to mention a giant cylinder you need to carry around, sometimes two.
They're fairly common upper-mid-tier cars in the EU, like Buicks here in the US. I'd reserve the description of "over-engineered works of art" for six-figure AMG cars.AZhitman wrote:Jesda - I think using Volvo and Saab as the benchmark, however, skews the results.
We're not talking about over-engineered works of art - We're talking about pedestrian vehicles with Hank Hill pricing.
I wouldn't call Ecoboost "expertise." In fact, I'd call it embarrassing. 350 hp and torque out of a MODERN V6 with two turbos and 16mpg combined in the real world? That's TERRIBLE. TERRIBLE! If you stuck two turbos on a VQ37VHR or an LFX, you'd be looking at 400+ ft-lb and better than 16mpg with NO effort at all. Hell, out of the box the LFX is making within 20 hp and 20 ft-lb of the Ecoboost V6 at the wheels and it's NATURALLY ASPIRATED. And the VQ37, while being short on torque, embarasses the Ecoboost six where horsepower is concerned, putting the same numbers to the tires as the twin-turbo abomination.Jesda wrote:Ford likely gained some of its Ecoboost expertise from a decade of Volvo ownership.
