evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Dec 06, 2006 8:42 pm
NA means Natraully Aspirated, which means there is no means of forced induction, IE no turbo or supercharger
as for the 100k, the biggie is keeping the timing belt replaced along with associated hardware, if you don't know when the last one was put on plan on doing it soon, other than that they seem to be pretty trouble free, parts wear out and break just like any other ar but nothing I consider milage dependant failure beyond the timing belt
just do your basic maintenance and be sure to use the proper fluids ( a lot of people use plain power steering fluid which makes leaks worse, ATF only)
