SBK03SE wrote:STICKY THIS THREAD!
1) Accelerator cable- Where is it? I find my Pathfinder is very light on the pedal, when I drive other people's cars I feel like I have to floor their pedals. (Perhaps mine was adjusted?)
2) Overdrive is my makeshift "Sport" mode. Always a thrill getting onto the highway and passing. Is there any detriment to leaving OD off all the time? MPG loss?
3) Knob dial on the wiper stalk, the manual says it adjusts speed, but I find it does nothing. What does it actually do?
1) If you have an 03, you have drive-by-wire rather than a cable.
2) Yes OD off reduces mileage. It says it somewhere in the manual.
As I understand it, OD is like a secondary transmission. It effectively fills in the space between each gear so that you don't actually have to have a gear in each one of those spaces (one OD gear vs 3 separate ones between 1,2,3,4th) This reduces the RPM at times, thus improving fuel economy.
Originally OD was added to cars so that at higher speeds, the wheels could actually turn at higher RPM's than the engine - hence overdrive as they were overdriven.
3) The knob on the wiper stalk is only adjustable when you've gone one "click" down on the whole stalk. This is the intermittant setting (gives a pause in between motions). The other 2 or 3 options are constant (no pause) but just incrimentally faster moving.
-Took me a while to figure that one out.
