MulleMeck »
https://forums.nicoclub.com/mullemeck-u270747.html
Tue Sep 05, 2017 12:46 pm
Hello! I'm about to order some parts (gasket kit, forged pistons) to my engine rebuild (TT). I was calculating the compression ratio and did get 8.49:1 with a 0.066" head gasket and 8.6 with a 0.060". Then it hit me, it mabye be better to machine/custom order the pistons and keep the original head gasket thickness. What is your thoughts on this? Some one a while ago told me that keeping the stock thickness is better.
Or does it matter that much with the compression ratio?(I'm aware that you can't boost as high with higher compression ratio). If I go with stock thickness I get 8.87:1. FYI I'm going to tune it with E85.
Regards Hampus!
