crookedcop7 »
https://forums.nicoclub.com/crookedcop7-u34140.html
Thu Dec 22, 2005 11:50 pm
I just bought an r32 skyline t28 turbo and wanted to know if Im going to run more than 13psi what thickness is recommend for more boost I believe that the stock head gasket is .8mm thick and alot of companies make 1.1mm,1.3mm,1.5mm's when I put the new turbo on I also will do 256 hks cams,rocker arm stoppers,550cc injectors, arp headstuds,300zx maf and a rom tunemy goal whp is 350
so what thickness would you recommend
thanks in advance adam
