I'm with Spec_V03........... normally white smoke is HG problem but for your sake I hope I'm wrong!!! Check your coolant as suggested above.spec_v03 wrote:i believe white smoke = coolant
have a compression test done, i'd guess a bad head gasket. keep an eye on coolant level and oil as well.
and if the precat is the problem, a header wont do much good, just keep it from getting worse.
