Thick White smoke and no boost....Blown Turbo?
nzmoman
Car: 240sx 2 of em' and always lookin for more
I just wanted to verify. Thick white smoke when throttled, a regular idle with no smoke, and regular engine temps, are symptoms of a blown turbo right? cause thats what my car does.
I have a T25 and the car made a loud pop/hiss sound. Im pretty sure it was the turbo, but I thought I would talk to some gear heads first and see what you all said.
B/c Im selling it I think I am going to go ahead and swap the turbo, when swapping for another t25 what will I need to do for prep? anything special?
Blown240sx
Car: 1996 240sx
Yea thick white smoke would probably be a good sign and if your not making boost. Sounds like seals are gone. Now if it was just white smoke with boost id say head gasket.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
White smoke means coolent, and Im pretty sure there is no way for coolent to enter the exaust piping from the turbo (the coolent passage inside the turbo doesnt come in contact with turbo bearings or seals, at least as far as I remember, I could be wrong). I'd put my bets on a blown headgasket, causing you to lose compression and leak a bunch of coolent. Any discoloration of the coolent in the radiator?
nzmoman
so I think I am going to replace my head gasket and head bolts and I will replace my turbo also because I love my baby. any recommendations on the best parsts for the best prices.
Also where is there a good online guide for doing this. wtf...how do you prime a turbo and the head after the install?
spider_slayer
Car: S14 240SX
S13 240SX
FSM.
