Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Fri Aug 26, 2005 2:46 am
THere are differences between brands such as type (oval, round, square) and material (alluminum, chromoly, paitned steel) of tubing, as well as the bushings design.
FOr isntance, cusco uses a little dust boot over their heim joint, while other don't..some have permanently lubed fittings (all you lsited should..),
Also, thread design and amterial of the adjustment peice should not be overlooked, zinc/teflon coated alluminum or chromoly is best IMO, since rust/freezing up won't be an issue...
That said, I prefer Cusco or Battle version, SPL makes nice stuff also, but will defer you to Cusco as -the- brand other follow for suspension component design.
-Chet
