These should work right...?
Rookie_ca18
Car: women, sleep, cars
http://cgi.ebay.com/ebaymotors...33554 < These should work since we can use dsm injectors right. Seem like a decent price, havent found any cheaper. Im about to order so let me know what u guys/girls think. Then all I need is a chip to run them and the z32 maf, I'll have 320hp in no time .
float_6969
I thought the DSM ones were too tall? I could be wrong. I got CA specific ones from NISMO in japan.
iliketocrash
DSM ones are the same size. just the top part that slides into the rail is taller and the bottom part with the little plastic coating is shorter. it all even out. i'm just concerned about the top of the dsm injector being too short and the fuel spray hitting the inside of the port walls instead of spraying directly into the air flow.
nismoplsr
those are what i bought.
The height is the same but....
the diameter of the top of the injector is slightly bigger, i mean by like 2/1000 of an inch. so the o ring wont fit inside the fuel rail. so i just drilled out the fuel raul ro the correct size and put a little silicone lube on the rubbers and they slipped right in
Rookie_ca18
Alright, thanks guys I think these will be fine. Any problems and Ill just do what nismoplsr did and drill the rail the correct size for these injectors. Thanks all. peace
float_6969
Another satisfied customer....
Rookie_ca18
<---- *keeping his receipt*
iliketocrash
i heard if you take the o-rings off the DSM injectors and put on the ones from your ca18det then they fit in fine. that's just what i hear. i didn't try. i think i actually cross threaded the fuel rail bolt holes in my intake mani trying to force those things in.
Rookie_ca18
oh aight I'll try that when I get em thanks.
nismoplsr
well it was the actual injector that wouldnt fit in the rail, meaning the metal above the o-ring was to big in diameter. Either way it was not a big job to drill out the holes. Just make sure that you get all the shavings out of the rail or else you might clog an injector and lean out a cylinder.
Rookie_ca18
Understood. *off topic* How difficult is it to install a safc? Not safc 2.
iliketocrash
i installed a safc-2 once. it was easy as pie.
Rookie_ca18
alright thanks, I guess the first gen safc shouldnt be much harder.
