I’ve been living with this problem now for almost a year. First 50% of brake travel does nearly nothing (has a tiny bit of spongy pressure however), at half way the pedal pressure appears. It’s not rock hard but fairly stiff at that point... it feels like how the top travel of a normal brake system is. It feels like the entire action of the brake system was slid down to half pedal (I hope you understand this). I can even lock up the front wheels when braking, so there’s good pressure in there.
s13 1993 fastback, non-ABS
***************************************************Chain of events of me ruining my brake system (I think?):
10/03: Stock brake system, nice stiff pedal. Brakes work fine, some screetching at low speeds from one of the rear wheels. After examining the problem, previous owner didn’t install the LR pad correctly (didn’t line up the nub on pad with hole in caliper). All pads still had decent life left except for the dragging LR. Have cash to burn, so hey why not do a little upgrade.
Ordered Brembo Blanks F+R and MetalMaster Semi-Metallic Pads F+R. Recieved brembo rotors and PBR brand semi-metallics... Maybe I was jipped, maybe I wasn’t... heh. New shims and clips as well.
11/03: Did the install and flushed the brake system with motul 600RBF. I thought it was a Dot5.1 but its a full racing fluid.... doh... doesnt comply with Dot specs! Had some early bedding in concerns which everyone helped me with. Brakes worked properly after fully bedding in, real crappy when cold during the first 500 miles of use. Improved after a while though (pads behave properly for semi-metallic now, and I have no problems with them).
Heres an old post of that event:
http://nicoclub.com/zerothread?id=42669
Every thing seems OK in Brakeland.
3/04: Rather than type out the whole situation I’ll link you to my old post:
http://nicoclub.com/zerothread?id=56459
Thread sounds a lot like this one eh? Sigh… I *assume* that the Motul RBF fluid soaked up fluid or something… but its strange how it just appeared at a light all of a sudden. I flushed it with some generic DOT3 stuff, didn’t help. From this point on the brakes have felt the same… spongyness and all till this day.
12/04: Pedal feels a little softer then before, so I figure I’ll rebuild the MC, maybe the Motul killed the seals? Maybe the old brake lines are bulging and adding to the spongy pedal? Well let me take care of that:
I rebuilt the MC. Installed SPL SS brake lines. Installed speed bleeders so I wouldn’t have to recruit someone for the pedal pumping (every one hates it). Bled the whole system with Valvoline Syn Fluid, 3L worth of it. Used the LR, RR, RF, LF sequence the FSM recommended, no bubbles visible from bleeders when done.
Unfortunately pedal is the same… with the 50% mark being more firm (because of the lines).
The only thing I can think of at this point is the brake booster. However:
*There is no hissing noise from the booster. (not leaking).*There is only a small RPM drop when brakes are applied (no vac leak).*I still have full assist from the booster.
Article on Zilvia describes how to get rid of some of the top spongy feel to the brake pedal. This is done by adjusting the output rod on the brake booster:
http://www.zilvia.net/faqs/arc...r.asp
My brake system has stock MC and calipers…. Why would I have to adjust the booster now after 100k miles of it being fine? What could have changed if the booster is at fault? I am worried that the brakes will drag if I readjust it, since there is a little bit of pressure in the top 50% of pedal travel.
Does anyone have any insight into this problem? I'm completely lost at this point.
