TrunkMonkey »
https://forums.nicoclub.com/trunkmonkey-u454.html
Sat Sep 14, 2002 2:11 am
you guys are going to make me do a bunch of typing aren't you?
oh well...
on older cars you can get away with removing the thermostat, but since the introduction of efi and emission controls, you'd be doing more harm than good.
when you first start your car the thermostat is closed, preventing coolant from flowing through the engine. the ecu senses this and does whatever it takes to heat up the engine (i.e. more fuel, higher idle (more air), increases spark, etc...). when the engine reaches a certain temperature it pops open the thermostat allowing the colder coolant in. the coolant robs any excess heat (the coolant is heated up) from the cylinder head and engine block, flows back through the radiator where it is cooled by fans and/or incoming outside air. once the ecu senses the engine is at operating temperature it changes everthing to normal operation (fuel, idle, etc...).
on almost all cars built within the past 2 decades or so, emission controls are affected by engine temperature. if the engine isn't at normal operating temperature, the ecu goes into a type of limp mode. the surging, stalling, poor driveability you get when you try to drive when the engine is cold (ESPECIALLY on the cooler/cold fall/winter months) is the result of this. if you remove the thermostat your car will take longer to warm up, therefore your ecu will stay in limp mode longer.
now that the elementary stuff is out of the way...
with or without the thermostat, once your engine reaches normal operating temperature (this should only take a few minutes depending on the weather), the ecu puts everything into normal operation. in the hotter summer months, depending on where you live, you might not need to warm up your engine for several days at a time. so, where's the power gain?
like i said before, if your car runs faster without the thermostat then something is wrong.
