Thermostat temperatures
WhiteKnight
Car: Nissan 240SX
1990 240sx. Should I buy a cooler one for the summer and a 195 degree for the winter? That's how it worked on the old camaros.Or should I keep a 195 degree in there all the time?
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
If you are running a stock engine i would say just stick with the 195 degree thermostat.
r3v_v3ng3
Car: 91 fastback ka-t
oem spec and use water wetter if need be
WhiteKnight
Car: Nissan 240SX
r3v_v3ng3 wrote:oem spec and use water wetter if need be
Translation request.
sx moneypit
1986 Toyota MR2
OEM=original equipment manufactuer.Water wetter is a coolant additive that helps with heat transfer.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
WhiteKnight wrote:1990 240sx. Should I buy a cooler one for the summer and a 195 degree for the winter? That's how it worked on the old camaros.Or should I keep a 195 degree in there all the time?
(D-Sport magazine) had a great article about this subject...they ran a few test's with cooler thermos and hot thermos on a dyno...result was hotter engine temps when controlled produce more power...this makes perfect sence and heat transfer is how horsepower is created...so its really a prefrence that up to you as a tuner...i do recomend reading that article online from the D-Sport website if ya can find it..
WhiteKnight
Car: Nissan 240SX
sx moneypit wrote:OEM=original equipment manufactuer.Water wetter is a coolant additive that helps with heat transfer.
I was wondering what temp is OEM.
sx moneypit
1986 Toyota MR2
According to my source the OEM thermostat opens at 170 degrees F.
WhiteKnight
Car: Nissan 240SX
Hmmmm 170 sounds low though. NOX is cleaner at higher temps.
sx moneypit
1986 Toyota MR2
Sounded low to me too ,but that is OEM specs.
WhiteKnight
Car: Nissan 240SX
I'm going to try the 195 the next time I have a day to pull apart the top of the engine...
The thermostat is buried under the steering pump in a SOHC
