IIRC, it's a 12mm nut, and 6mm hex keys for the other two bolts. You use liquid gasket NOT A TON, just a smearing. And you have to clean both the the housing and the pipe very well to get the old silicone off. Let the gasket set for many hours/overnight before starting or you'll be sorry.herewegosteelers wrote:My radiator cracked on top when i was charging the ac. I was going to change the thermostat when i looked at the 3 nuts/bolts two of them are a normal nut and one is some kind of hex or something anyone know if this is normal? how do you change it? and the parts store said no gasket is required?
