thermostat overheating
Juujai
common problems but can't solve =/
thermostat problem solved nm
my windshield wiper isn't working. i posted this up before but had no replies. i was relocating my wiring harness from the left side of the fender and accidently chopped the windshield wiper harness. i soldered them all back together and the wipers doesn't work anymore. its really bad since it just started raining =/ any help what i could check on? fuses relay? i tried bashing the green box
3rd problem:my clutch pedal falls to the ground. every 2-3 days. i know its leaking fluid but i'm not sure where. i had someone pump the clutch pedal nonstop while i was under the car checking for leaks. i went through the hardline, and clutch line couldn't find any fluid at all. i've searched and been told master or slave cylinder but whats strange is i can't find leak at all. any help? i'll probably go ahead and get new master/slave but i don't want to buy parts if that wont solve the problem
thanks guys
Modified by Juujai at 12:59 PM 4/4/2006
ricebike
2002 Quest
2005 Altima
well, if you're definitely sure that there's no external leaks @ the slave or behind the master cyl into the cabin, pedal is adjusted properly, the rubber hose to the slave isn't bubbling out when you depress the clutch pedal (i've seen this happen 1 time, but w/ a brake hose),and you rule out NO air bubbles in the system...
then guess it's an "internal" leak that can't be seen... so change out the massa cyl.
