i dont know if its natural but my car just started over heating after i installed my nismo theremostat the needle keeps fluxuating
can somone show me a picture of which way the nismo thermo stat is sapposed to face. is it the tip towards the engine or the tip towards radiator. if somone could help with this without saying check search and shyt it would help alot thankyou.
I'm no mechanic but when I changed my thermostat I had to "bleed" it. It kept fluctuating until I did this. All you do is loosen/remove the bolt that says do not touch when hot, then you keep adding coolant to the radiator until you get a steady flow of fluid coming out of that bolt, close everything up and wah lah...
