IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Tue Aug 03, 2004 8:17 am
first off, the hole MUST be on top. if its not, go back outside and take it apart.
if the "o ring" is rather thick, with a groove around the inside, then the rubber goes around the thermostat. you get what im saying? the outer edge of the thermostat fits into the groove in the inside of the rubber ring.
if it is a real o-ring, then you should see a groove that it fits into. either on the outlet, or the housing.
