G35Rican wrote:at infiniti $67 at nissan $29, autozone was $20 but i had never called nissan till today.
So you saved $47 with $100.00 of aggravation
Did you follow the instructions in the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2003/co.pdf
" Overflowing reservoir tank
Exhaust gas leaks into
cooling system"
Did you ever perform a pressure test and test the radiator cap?
G35Rican wrote:
any suggestions??
if the radiator is not from Infiniti that could be a problem as well as the water pump?
Take it to the dealer and use this as a learning experience.
Buy cheap, buy twice with lots of hours and hassle in between
Good luck
Telcoman
