nope it needs to be KA sensor KA gauge, change it out see what happens.lilskyline240 wrote:no im using the RB sensor for the KA gauge. Do i need a KA sensor? i was under the impression the RB sensor would work
no it doesn't, change out that sensor to the KA temp sensor, you should be fine after that.lilskyline240 wrote:thats the reason its not working? shouldnt it register something tho? the needle never moves. Im pretty sure that my thermostat is good, i think i just have a big air bubble in the lower hose that i cant get out because the stupid greddy plenum doesnt have a bleeder valve to bleed the coolant system
I didn't splice anything, I used the gauge they provided and the sensor the provided. The sensors are meant the register with the proper gauge.....daveh93s13 wrote:what wires did you splice your gauge into? i used the blu/blk and spliced it into an autometer gauge, it reads but reads high, around 225 im going to try re-bleeding. im getting gd heat, it just runs hot. but make sure the wires you splice into are correct.
You can't splice an Autometer gauge into the Harness and get a correct temp. There is a Sensor that comes with the Autometer gauge you need to use for the correct temp. But My first Gauge I bought (Cheap electronic) I spliced into the factory sensor signal and it worked ok for a while then the gauge took a dump.daveh93s13 wrote:what wires did you splice your gauge into? i used the blu/blk and spliced it into an autometer gauge, it reads but reads high, around 225 im going to try re-bleeding. im getting gd heat, it just runs hot. but make sure the wires you splice into are correct.
