YomnyM »
https://forums.nicoclub.com/yomnym-u9120.html
Sat Feb 22, 2003 9:33 am
I have a problem, my car's overheating weirdly. The car drives fine for about 15 mins, after that the temp needle stays at normal range but, the engine starts making noises, like pistons or valves knocking, sort of liek when you put 87 or lower octane gas and hwen you accelerate it knocks.. Whats happening is that the water is evaportaing, it's not leaking or anything, i've checked tons of times for leaks, now the Thermostat is good, i flushed the radiator and my overfill tank never fills up. But i add water to the radiator one day and the next i have to add more, it evaporates it. It gets so hot that when i pulled the dipstick out to check, smoke was coming out, and it doesn't mark any oil. The car does have oil, is full. I've already tried getting all the bubbles out. Any help will be greatly appreicated i dont' know what else to check. How can i check the water pump? Thank you very much
