Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Jul 09, 2004 10:09 am
I agree. Lower temperature thermostats do not solve overheating problems. Consider that at 200º F, both the OEM and the Nismo thermostats should be wide open. Both will provide the same cooling above that temperature. Since you are overheating, your water is getting over 240º F, and a colder thermostat won't help you.
Colder thermostats are for keeping properly cooled engines at a lower temperature, usually for only one reason: to reduce knock. If your engine is knocking but not overheating, then using a colder thermostat (as well as colder plugs) may help. If it's overheating, then fix the overheating problem first. Then go after the knock, if it is still present.
