thermal vacuum valve
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
cedar
Car: 1984 720 4wd KC
i searched the forum for a bit and didn't find anything so i thought i would ask.
the top two vavuum lines attached to what i am fairly certain is a thermal vacuum valve are broken off. does this matter much?
should i replace the TVV? or can i just forget about it for now.
this is an '84 720 Z24 its a 4x4 with ext cab
here is a pic. it doesn't clearly show it, but the top two lines are completly broken off, they just happen to be resting where they should be in this photo.
thanks!!!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
yeah I was about to ask about that thing too. I want to plug it up is that a horrible idea?
breadbox
89 Koop
84 720 4x4KC
We figured out the round white plastic thing under it in the pic with two vacuum lines retards the timing after a preset something something.
4wheelsoffury
Car: 1985 nissan 720 kingcab ST 4x4 2.4L Z24
from what I know (cause I broke mine trying to replace vac lines) it opens the egr valve, when the coolant temp gets hot enough this tvv sends vacuum to the egr, newer cars have a solenoid that does this. I capped off the lines to the tvv after I broke the connectors, and was planning to get a new tvv, but it has run just fine for over a year.
PEZi
Mine is all plugged as part of the emissions delete.
cedar
thanks for the replys!
pretty much what i figured, i'll probably just plug it for now.
breadbox
89 Koop
84 720 4x4KC
woot.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
yeah it controls the egr, its not necessary for running good just more emissions crap. mines plugged. as with every other port except the vac line to the dizzy.
heyman421
Car: N/A
It also retards the ignition during choke by defeating the vac advance while the engine's cold.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
According to my 82 FSM it controls distributor vacuum advance. If the valve is open it will stop distributor vacuum from advancing.
synack7350
why would you want that too happen rev? that doesn't make any sense.
Rev_D21
I guess the valve controls timing until the engine is warm. This is coming out of a 82 FSM.
PEZi
^ yep
Once its warm it runs as if it were plugged, it only does something while the truck is cold. Not really a key part.
synack7350
lol I hate retarded timing!
Macks96HB
Could this be my issue?
96-hardbody-won-t-stay-running-help-please-t537053.html
Help me please!!!!!
Return to “Datsun 720”
