Phifross wrote: ↑Mon Nov 21, 2022 10:16 am
I'm looking for the coolant temp sender, which sends the temperature signal to your dash gauge. Some call it also the Thermal Transmitter.
Yeah. This one had me a bit turned around awhile back. The Nissan factory service manual refers to it as a thermal transmitter, but I found nothing in Nissan's FSM that showed me where it was located or how to check it and the instrument panel gauge. The FSM speaks to the functional check of the ECT sensor and has a rough indication that it is located at the center of the engine and below the intake plenums. My Haynes repair manual details the check and replacement of the coolant temperature sending unit (aka thermal transmitter) but has nothing about the ECT. Between the two manuals, I have sort of a complete picture now. Neither one of these sensors is easy to get at.
The temperature sending unit is located low, at the rear of the engine, on a water pipe. The picture below is from my Haynes manual. I also posted a picture of the check and replacement instructions so that you can determine if it is the gauge or the sensor that has gone bad. The other two pictures are the two temperature sensors. The ECT sensor is 25080-89907 and the one that controls the instrument panel gauge is 22630-ED000.
