Thermal intake gasket question:
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Alright guys I'm trying to find the torque specs for a Circuit sports thermal intake gasket if they are different from stock.Stock suggests 13-15Ft lbs but imo that seems a bit weak because this isn't a factory gasket.Let me know what you guys run torque wise if you have an intake spacer like this!
edit: should b obvious this question is for an SR20det rear drive engine.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I just used the factory torque specs and have not had any problems.
cody180sx
Car: s14 rb25det fully built 550whp coming soon
but i just eyeballed it 10 to 15 ft/lbs you can do with 1 hand i've had no problems
Didderson
'74 Datsun Z
Ok sounds good I will do the factory specs then!Thanks all
