Thermal breaks on the intake
reggiegsd
Car: '94 Q, '73 240Z
Just out of curiosity, has anyone tried making phenolic spacers for the lower intake manifolds to attempt to limit the temperature increase on the intake air?
I figure a half inch thick and an easy way to do some port matching.
Through in some insulation in the V and you might find some power on a hot day.
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
With our luck it's so carefully tuned for runner length that it would make less power!
DAEDALUS
So maybe get a machinist to shave off some of the runner, and match-install a spacer. Glass Ultem has a phenolic base I think and is easy to work with. LP509 glass-resin would probably work well too. I think 1/2" is way too much though. 1/8" would probably be very effective.
Q45tech
The problem is on a cold day since the injectors are so far up the runner from the valve seat.
http://www.grapeaperacing.com/...d.cfmh ... m/...z.cfm
reggiegsd
I was thinking about the effect moving the injectors out would have. Maybe shaving or cutting nd rewelding the manifolds is an option. Not necessarily a good one, but an option.
Another option would be to aggressivly cool the intake manifold.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
How about cooling the intake charge in another manner? Like using water/alcohol injection. Seems to be easier to set-up.
I know what a pain it is to take-off that plenum. I would not do it again, unless it was necessary.
