corey240 »
https://forums.nicoclub.com/corey240-u32370.html
Mon May 28, 2007 3:03 pm
bleeding the lifters is very simple and you should do it just to be shore plus it will help anyway. also, put your valve cover and where the gears are on the enof the cams, theres a space between them where the chain runs over to the other gear, over the is a plate of metal, just take a size 12mm i think it is ratchet or w/e and unbolt that plate. its ok to leave it off and look at the bottom to see if its got stratches and what not, either way i would leave it off.
