ELI-G wrote:thanx
Burning oil smell most likely is the Valve covers. When was the last time the spark plugs were changed? Have you done your chain guides? Or have they been done? At your mileage, if they go, burning oil may be the least of your worries.
I have a 92 and I had the same issues. VC reseal, new plugs, chain guides, and hoses turned my Q into a monster.
For the vibrations, it could be your driveshaft. It's not crazy to suspect it at your mileage. The rubber bearing is probably shot.
See what you can do as far as getting some vehicle history together and letting us know. Then we'll be able to help out more.
maxnix wrote:First, RTFSM!
Remove the top plug first. Fill should be up to that orifice. If you can't feel it, drain and replace. Car must be level. A lift is a lifesaver.
All conscientioius owners replace all fluids and filters for a known baseline unless there is solid documentation to the contrary.
Acronyms for new members might be a little "broken pencil". How hard would it have been to just say "Read The Factory Service Manual"? Why do you assume that he even knows what that is?
