EW wrote:You will not be able to get noise out of some products especially if they are cheap. Unplug the rcas at the amp and see if you still have noise. On some amps, I have had to ground the rca shield to get rid of noise.
Nothing is cheap in my system really, I didn't go out and spend close to 5 figures but it's all decent (kenwood deck, quart amp, cdt/Image Dynamics). I can't rule out a defective component though.
I did do a check on the interconnects already, I will be rechecking them with a meter as well. It's not at my house right now.
I may try to ground the rca's and see if that helps...
