Theft Inhibit Relay????
1FLQ45
In reference to the ECU where exactly on the passengar side kick panel is the theft inhibit relay located????
Thanks in advance
Q451990
If I remember correctly, and we're talking about a 1st Gen Q45 it's behind the ECU... If it hasn't been disturbed in the past there should be a layer of crumbly foam in front of it.
Heath
1FLQ45
That's exactly where is it located, behind the ecu. Took me a while to find. The FSM was not that useful for finding this relay. Thanks for the reply.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Im pretty sure its the brown one, the blue one is the bose amp turn on.
1FLQ45
According to the FSM, it is the black one. After removing the ecu you will see a thin piece of sponge or foam, the relay is behind that. When you look behind the sponge you will see three relays in a row, the alarm relay 2 is behind the 3 relays.
