So I bought this car with 72k on it. I then, over the years, while sticking with the stock turbos, upgraded everything else. Injectors, SMICs, brakes, driveshaft, OS Giken twinplate clutch, etc etc. Basically everything that could be done short of yanking the engine for tubos, was done. Then the throttle butterflies decided they wanted to stick open at WOT in reverse getting up my driveway.
Then a bunch of body work was done, including Escort FRP front and JDM lights and stuff in the back and skirts and new paint, new glass, and and...
So here we are, with >400hp on stock turbos, and I'm bored with the power. Let's send it off to ZSolutions, with Brad, in Alabaster, AL.
This is where it is now.
It's getting JWT 700s, manifolds, bigger injectors, and a built shortblock, new wiring harness, even bigger injectors, more, more, more. Since my old engine was sounding tired, what with an oily intake and borderline comp. test, the new shortblock with forged everything should work well. Hoping to hit 600, but will be happy with 550. Also refreshing the suspension with new Koni bits, and even bigger brakes. What do you guys think? Only thing left down the road a far as I see is maybe a 100 of the gas, but I'll have to get used to driving it again first.
