Only to the people who haven't yet visited z31club.comJaysun wrote:Here's one you may have not seen:
[Doesn't it seem like the best Z31's are all from Japan?!?!]
he is known as butters on other sites he was going for an "old school" bumperless look so he tucked his bumper and swapped the 87-89 front end to get the better more modern sleepy eye lookevildky wrote:wow!, I love the tucked bumper and molded spoiler, I think with the 87-89 rear it would be even hotter, but the ZG flares are best left to the S30's and the grapefruit shooter has gotta go, and it dtrives me nuts when people get a 10" wheel and only enough tire for 8"
Only problem with dental floss is that it isn't very strong. Fishing line works so much better. Be sure to wear thick gloves to protect your fingers from getting sliced open.sharjt wrote:Take some dental floss and run it under the molding slowly. You can usually get the off pretty easily if you add a little heat as well. The only problem is paint discoloration under the molding.
Even betterAZ-ZBum wrote:Only problem with dental floss is that it isn't very strong. Fishing line works so much better. Be sure to wear thick gloves to protect your fingers from getting sliced open.
x240xdrifter wrote:me likey me likey
It's an engine swap. RB25DET from a Skyline R33.evildky wrote:how about a better underhood pic? is that a pathy manifold? or an engine swap? hard to tell from that pic
What body kit is that? It looks like the Kaminari kit but that does not have the open section at the bottom does it?Flicktitty wrote:
