The twins car had a hx40 on it. They held the stock block hp record for a while till cory took it. They were on 30psi and made a little over 520whp i believe. Search for it and you might find their video.Tofusamurai wrote:Anyone here running a Holset HX40 on a KA? I know it will be laggy, just curious as to how much. I know it flows 70lbs/min, and that is quite a lot. Any info regarding the HX40 will be greatly appreciated. Looking to run it at 1 bar till I get pistons and rods. Thanks a lot.
Add heat and use big channel lock pliers n twist ever so gently should come apart.. air hammer makes me cringe.nelson8708 wrote:cool...so its a Hy...any suggestions on how get the turbine off?
this particular H1C has a bigger compressor. i have no need for the hx35. i got good results on my kA from the older smaller H1C also it was free lol. its bigger and better than the t28 on my current rb25Reno wrote:Biggamehit why H1C over HX35??
what are the specs and would you ever consider a twin-scroll Mani?Biggamehit wrote:
Yeah I scrapped the stock turbine housing due to internal cracks in the housing. and picked up a non gated housing, so the highest you took your boost was 15psi and didn't run into any problems? I was planning on taking it to 20psi at max just curious to know if anyone has experience boost creep around 20psi on a 38mm wg.Biggamehit wrote:i run a Tiall 38mm
you only want to run a 44mm if you are seeking mega boost. there has been talks of the 44mm being good for guys such as myself who didn't exceed 15psi to prevent boost creep. I never had an issue with that with my 38mm.
whatever you do... you don't want to use the Wastegate that comes with your holset if you aquire a WHx35 etc etc etc
Was?Biggamehit wrote:this setup is only about half a year or so old and was doing very well....
<25psikentuckyslider wrote:How much boost do you think I'll need from my HX35 to max out my tune at 450-475whp? I have 86.5/8.5-1 pistons with tomie 260 procams. There is a SR with stock cams making 350whp on a 1bar spring with the HX35 on the SR20RWD forum.
