White Comet wrote:what all harness did you tuck? most of the normally tucked wires shouldnt really effect the cluster or tails.
well im running a gutted interior, so I decided to tuck the wires in the cabin as well, mostly at the back section where the tail lights and signals are. i tucked the harness in the engine bay but it was mostly engine/lower harness related items.
on the back side of the car i removed the rear side markers for the brakes (since the hole for the lights were welded shut. the third brake light on the hatch was also removed. the rear speakers, antenna, hatch defrost were also removed since i had no use for them. i cut the connectors off since there was no use for them. my reasoning for cutting them was because the rear sections share a common grounding point, but have independent power wires.
hungryjoseph wrote:do your dash lights also turn on with the rear tail lights when you tap the brakes? if so, it sounds like you put the bulbs back in the wrong order. there's 2 different bulbs in the rear, and when you misplace them, that is what happens. i can't really help you with your other issues
the bulbs were never removed during the process of swapping over the tail lights or during wire tucking the rear. with the analog cluster connected, it's illuminated whether or not i pump the brake pedal. when the digital cluster is connected, it's not lit up whether the pedal is pumped or not.
there are two things that the tail lights and signals have in common:**Super Multiple Junction****Headlight switch**
Looking at the diagram, the red/lavender wires command illumination of the car. from the back, connects to the SMJ, then goes to the front. the illumination switch splices into the same circuit. i might swap it out for another working one to check if it works.
Maybe it might have something to do with the SMJ, since the problem circuits all junction there.
