The wiring to my knock sensor doesnt look correct check these pics out
MR.chris
Car: 1995 Nissan 240sx se SR20DET Money Pit
I think that the wiring has been modified. I dont understand why the + and - are wired together and if you look closely at black plug there is only one female post but the knock sensor itself has two male posts. My car still doesnt run right and I think this could be part of my problem. What do you guys think?
MR.chris
Someone has to know the answer to this question.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Nope, it's fine. That's the way it should be.
The sensor grounds through the engine block, and the one wire is signal, the other wire is the shield ground and should only be connected at one end.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Seishuku wrote:Nope, it's fine. That's the way it should be.
+1 That is correct!
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
winner :D
