The Wiring Chronicles of NICO's Autocross Truck
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
PEZi
It's about time..... custom wiring going into the 720! Follow along as I kill myself on another stupid project!
meh :/
MetalFab
Car: 1985 720 4x4 reg cab flatbed.
*shudder* looks like a nightmare to me. =)
drumaniac3000
Car: 1986 720 4x4
Time to start fresh...
PEZi
Day 2... wire mining! Pulling out some of the crap that I don't need.... but realizing that doesn't even put a dent in this crap yet.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
So I got my truck running and now it has charging issues and wiring demons. LMK whats up with a wiring kit.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
man I'm so not looking forward to this part. Good luck with all that pezi.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
That's hardcore!
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Saw a lot of wires going nowhere when I installed the blower for the AC. I'll be doing something similar when I'm changing the dashboard.
breadbox
89 Koop
84 720 4x4KC
Have taken pictures of the plugs and colors with their label.
synack7350
wish I could help man always an opposite coast thing!
PEZi
I'm still in the process of making all this work. I have the ignition completely separated and working, and then the new electric fan wired and voltage gauge wired separate from the rest of the harness. Headlights are separate, and work as well! I still have tons of wires... still figuring out what a lot of them do and what can be ridded of. Right now, I have no working blinkers, tail lights or brake lights... but I am THAT close to a completely functional simplified harness! I'll let you know once I have those things working and what ends up being left.
synack7350
I take it that's a painless wiring set up? how much did that cost?
PEZi
As of right now... everything is still the stock wiring, and I have manually pulled all the crap that doesn't need to be there. I have wired a few things back up, but overall the cost is minimal so far. The reason I have no working lights is because I pulled one too many relays :facepalm:
synack7350
I'd forgo the relay anyway. you can get a 5 dollar old school pull switch that can handle the amps of your lights. It's what I'm gonna do when I get in there.
PEZi
Oh, I know. I have the headlights working currently, but I still have to make the tail lights, brake lights and blinkers work.
synack7350
what gauge wire did you send to your headlights? do you remember?
PEZi
Headlights are still using stock wire... appears to be 18.
synack7350
yeah sounds about right ish. 50 watt bulbs be around 4 amps a bulb.
Return to “Datsun 720”
