sXi »
https://forums.nicoclub.com/sxi-u27000.html
Thu Nov 03, 2005 6:12 am
when I first noticed it, it was couple days ago. I drove 50 miles high way, the water temp needle was at normal position during the high way trip. then I hit the local streets, the water temp needle suddenly almost hit the H position. stayed there for like 10 second, then it started to drop while the car is movng. from that point, the needle stayed at the 1 bar above normal position.
since that day, the water temp needle keep doing the same thing. it acts normally on the high way, but when I am driving the in the local streets. it just scares me ...
before the 50 miles trip. Ive a spot of coolant under the car, i think half foot wide. so i went under the car, looked like coolant was leaking from under the water pump. the is a little hole under the water pump correct? so, I filled the tank and the radiator, make sure everything was good to go.
any idea what is wrong with the temp. thing? thanks
