I will use this thread to keep everyone updated on what is going on with the A-31. So far this is what I have received regarding my email to
http://www.japanesemotorsports.com.au who has helped me do my swap (the best they can from the other side of the world... mind you I did my swap before I knew of this forum or anyone on it).
So... about the A-31 X-member... here is my most recent email:
We still don't have another A31 crossmember here to compare it. On Denzo's S13 with RB20DET, I believe he simply manufactured a couple of plates to fit the RB onto the S13 crossmember - but this might not work with the 240sx. Good to hear you're up and running anyway.
Regards,Ben
NOTE : i had ordered a A-31 a while ago but it was stolen off of their lot... that's why he said "still don't have" FYI
So it is sounding like there are 4 options to me:
1) Use the Skyline X-member and cut the hood bracing
2) Modify the the Skyline X-member so that it is lower (make sure to leave enough clearance between the steering rack and the oil pan... don't want them touching)
3) Order a Cefiro A-31 front clip equipped with a RB20DET and see if that will work... this is assuming you haven't ordered a clip yet... might be worth a shot
4) Just order a A-31 and find out... let us know if you do!
I am personally going to look around and shoot out some emails to other companies/tuners that might know if there is any difference between the two. More than likely I am either going to fab up a new X-member or modify the skyline one to lower my motor.
So for right now the group buy for the A-31 is going to be put off. I welcome any comments and critisism on this subject! We all learn through each other... that is what makes these forums great.
Regards,Sig
