Concidering the weight and power benifits its actually a pretty good deal. Over 100 lbs or more off the front of the car and an extra 10-55hp never hurts (unless its a s13 sr20de). People pay $500 to save 12 lbs with a carbon fiber hood, thats about $42 a pound. So concidering you get around $4200 worth of weight savings, a more balanced chassie and some extra ponies, that S14/S15 NA SR starts to look like a good deal. Obviously not optimum for a drag car, but a curb weight of under 2300 lbs would be fairly easy to obtain (lighter and more powerful than any mazda miata), it would eat other cars in the corners.Turb0wned wrote:all that money ur gonna spend on a N/A s15 engine is just not worth it to go N/A
You use the VE head on a RWD DE engine, and there aren't any cams currently available for the VE engines other than the N1 cams which would be around 205whp all together WITH high compression pistons.dareo wrote:Build yourself an SR20VE. It can be converted to RWD, and you could setup ITBs if you got a standalone. Do the cams and a great job tuning and you could be 200-230whp.
