As things sit, here is my current mod list...
Installed
SZ 3” Down Pipes
SZ 3”-2.5” Test Pipes
Stillen 2.5” Catback Exhaust
Selin Dual MAF Translator with 2 JWT POPs
SZ Subframe Spacers
Greddy Turbo Timer
IPP SS Clutch Line
Chromoly Clutch Pivot Ball
Fidanza Lightweight Flywheel
RPS Max Street Clutch
Rear-Kumho Ecsta XS 275/35/18 180/AA/A
Front-Kumho Ecsta XS 245/40/18 180/AA/A
In the garage
UO Underdrive Pulley /w other Pulleys
http://www.z1motorsports.com/product_in ... ts_id=1577
HI Overdrive Water Pump Pulley
120K Mile Timing Belt Kit with Ramey Idler Bearing Studs
SZ Z32 Expansion Turbo Outlet Pipes
AshSpec Massives V2s SM Intercoolers
AshSpec 2.5” SMIC Piping
AshSpec 2.5” Planar Inlet Pipe Kit
SZ Chip
SPL Tension Rods
Because of a number of issues that have come up a lot of these parts will be sitting around for a while. Basically here are the only things I have planned...
Greddy Profect B Boost Controller-
A guy I work with is going to install this for me...when, is the question...He has said he would do it now for a couple of months but keeps flaking out.
He actually offered to pull my motor this winter and it sounded like my wife would be down for me ordering the rest of the parts (which would be around 3K) but I just can't do it. If it has taken him over 2 months and 20 "lets do it tomorrows," I strongly question his ability to find time to do an engine pull. He said it would be easy to do it in the winter because he has nothing going on but I just can't risk it. I can't spend 3K on parts just for them to sit around...
Because of this I figured I would use what I could...that being the AshSpec Massives.
Intercooler Coupler Adapter Kit-
http://www.ashspecz.com/shop/prodInfo2.php?prodID=47
This will at least allow me to use the Massives even if I can't use the piping
120K Mile Kit (with Pulleys)-
This WILL be done by next summer whether my buddy does it, my friend's dad, or a shop. It needs to be done.
I have come to terms with the fact that many of my parts will be sitting around for a while so I made a decision about my next course of action. No more breather mods for my current engine…The next step is balls out on a new engine…
Before I get into that I will tell you about a previous goal (which most of you are familiar with) and that is a sick stock turbo Z. This is copy and pasted from my old thread, so if you are familiar with it, you can skip this part…
My goal is to make the most powerful stock turbo Z. I am aiming big and shooting for 450 rwhp on pump gas. If you want to tell me that is not possible, you may as well save it. Though I do think it will get that high I want to aim big. Here is a link on the SZ blog of a stock turbo Z making 419 rwhp on 91 octane at 14 psi and I plan on doing more than he has done…
http://specialtyz.com/blog/?p=441
Here is the planned list of major mods as far as the engine goes...
Engine will be installed by SZ and tuned by SZ
Rebuilt VG30 Long Block by IPP with JWT 500 Cams
BDE Upgraded VTC Intake Cam Gears
Tomei Exhaust Cam Gears
New Stock Turbos
HKS Internal Wastegate Actuators
BDE Motor Mounts
SZ Oil Pan
New EFI/EGI Wiring Harness
New Alternator/Transmission Harness
AshSpec Massives V2 Intercoolers (Have)
AshSpec 2.5” SMIC Piping Kit /w SZ Coned Outlet Pipes (Have)
AshSpec 2.5” Planar Inlet Piping Kit (Have)
Z1 Upgraded Throttle Bodies
Selin MAF Translator with JWT Dual Pops (Have)
Koyo Radiator
Z1 or Stillen Engine Oil Cooler
Nismo 740cc Fuel Injectors
UO Underdrive Pulley 4 piece set (Have)
HI Water Pump Pulley (Have)
3” SZ Down Pipes (Have)
3” SZ Test Pipes
3” SZ Catback Exhaust
Mike Smith Exhaust Manifolds
Z1 Platinum Series Driveshaft
RPS Max Street Clutch (Have)
Fidanza Lightweight Flywheel (Have)
Greddy Turbo Timer (Have)
SZ Chip (Have)
Blitz SBC i-D Spec-R Boost Controller
SZ ECU Map Selector
Snow Performance Stage 2 Boost Cooler Water Injection Kit
This plan has changed (hence the “uncertain” in the title.) I am going to make the sickest stock turbo Z…until I can afford to go big with SZ EXP90 Turbos. The motor and mods will be built for the EXP90s but will run stock turbos until that time comes. That will allow me to save up for the turbos with DPs ($4,354,) a second fuel pump ($300,) and possibly a FMIC (TDM-Works FMIC Kit,) though I think the Massives with larger piping will work (possibly $1,850.)
Here is what the new engine will be…
Stage 6 IPP built Long Block-
http://www.importpartspro.com/st5vgloblni3.html
I am sparing no expense and going balls out with the best out there. Here is a list of what the package includes…
This Stage 6 Nissan VG30 Long Block engine package is for a Nissan 300zx that wants serious power and the strongest engine available. This package will be good for up to 1200Rwhp and 8000 Rpm Rev Limit. This is not for the faint at heart!! The Stage 6 VG30 Long block comes with a full one year warranty against machining defects and comes with our 10+ years experience on building Nissan motors.
This Package Includes:
Products in bold are upgraded from previous stage
CP Pistons with full ceramic/moly coatings
Pauter or Carillo Rods
ARP Rod Studs
ARP Main Studs
Block Inspected and acid dipped
Block redecked
Block water passage bored out for more water to back cylinders
Block Bored and Honed using a Torque Plate
Crank center weight tig welded into place
Crank balanced
New Moly Coated Race Spec Main bearings installed
New Moly Coated Race Spec Rod bearings installed
Block prepped and assembled
ARP Head Studs
Tomei Cams(Your Choice)
Tomei HD Valve Springs
Tomei Solid Lifters
Titanium Retainers
Ferrea 1mm Oversized Valves
Heads inspected and cleaned
Heads Pressure Tested
Heads redecked
Ported exhaust and intake runners
5 angle radius cut valve job
Combustion Chamber work
Valve heights set
New OEM Valve stem seals
Heads prepped and assembled
New OEM Cam Seals
New Cometic Metal Head Gaskets
New OEM Oil Pump
New OEM Oil Pump Gasket
Engine will come with Heads bolted to block and torqued to spec.
When the time comes I will have the engine shipped to SZ. I will have SZ install it and send them back my old engine. I will also have SZ do the other required maintenance and modifications for the
larger throttle bodies (going with RobZ) and the BDE Top Feed Fuel Rail Kit. At this point I can have my larger piping installed along with BDE motor mounts, MSP Manifolds, BDE Intake Cam Gears, Tomei Exhaust Cam Gears, and new stock turbos. At this point I would probably want a CF driveshaft but I might actually wait on full 3” Catback exhaust ($1,200 + the $360 for new TPs.) Finally an SZ tune. Credit will be used on this purchase…
