The Turbonator
InfinitiAndre
Car: 1997.5 Infiniti J30
Does it really work???It sure convinced me!
Tell me what the deal with this thing is, and how will it adapt to the J?
I also have a aftermarket intake... so can it be installed between the Air Intake Sensor and Engine?
http://www.turbonator.com/index.html
DominickJ30
Car: 1993 Infiniti J30t
Short story no it doesnt work. All it does is slow down the air intake speed thus reducing engine performance.
J30Guy612
Noooooo!!!
InfinitiAndre
The reason why it convinced me is because I read on the IS300 forums a person put it in his IS300, and did a dyno and it increased his raw HP a great deal! He took it out did another dyno, and bam, HP gone! So if I did not hear about that real life experence, I would never even considered it.
Here was his reply:
"yeah, it works very well.
It easily put down about 35 rwhp and 17rwtq when we strapped my car to the dyno. when we took it off, the hp and tq numbers dropped immediately. then we threw it back on, and the numbers climbed up again.
next, we tried spraying wd40 into the intake piping (took the filter off) becuase it boosts the octane level, and almost works like nitrous. sure enough, i almost got an additional 50rwhp and about a 30rwtq bump. if i recall correctly, i was pushing about 275rwhp with just an intake pipe, and the turbonator and the wd40.
screw a turbo, or research and development. that stuff is just a bunch of mumbo-jumbo to get you to pay more. do what i did and go for the cheap smarter route. my mechanics and i are thinking of rerouting the washer nozzle hosing to the intake pipe, and fill the reservoir with wd40. (cheap nitrous, no solenoids to fail)
i'll find the video later. good stuff. you might be able to search you tube for it too."
gr8scott72
Car: 1994 Infiniti J30t
InfinitiAndre wrote:The reason why it convinced me is because I read on the IS300 forums a person put it in his IS300, and did a dyno and it increased his raw HP a great deal! He took it out did another dyno, and bam, HP gone! So if I did not hear about that real life experence, I would never even considered it.
Here was his reply:
He's smoking some good stuff.
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
the idea that a lot of people get wrong is that if the flow of air goes into the intake as a vrotex, there is going to be a vacuum at the centre of it, and that vortex will break once it hits the throttle, and since the flow of air will take the shortest way, so instead of enhailing more air from the filter, it would also suck some air out of the cylinders, and actually causing the engine to run rich, moreover, it would cause hesitating, i dont know if that made much sence
Defiant
Car: 1997 J30
What a bunch of crap. WD-40 gives a "boost" because the propellant is propane. But there's no way in heaven or hell that it'll give fifty horsepower.
Damned meth.
gr8scott72
Defiant wrote:What a bunch of crap. WD-40 gives a "boost" because the propellant is propane. But there's no way in heaven or hell that it'll give fifty horsepower.
Damned meth.
Only when you combine it with the turbonator. lol
