chano129 wrote:Now mister moderator sir, with acknowlegdement of you being here, i want to show you why , this guy(lomax) thread miss the whole idea,and partly mislead the forum to only think it is because driving at 2500 rpm you have good mpg,he is correct about the theory of less fuel enter the engine at 2500 rpm,, but that is not the main reason why it is important to drive the VERSA a that 2500rpm, the main reason is the engine was particle design to reach or achieve at least 90% of it torque and power at 2500 RPM, is was design for that purpose for fuel efficiency, and the torque converter is different from the older torque converter, and i think it called: a lock up torque converter.That is why the CVT can reach its maxium range, because of the gears of the CVT in the epicyclic.
I know you are saying that since the engine is at it's optimum performance range, it is better for gas at highway speeds, but my whole argument was that you said the CVT has gears, which was what you originally tried to explain to people. What you quoted in one of your posts above was absolutely correct. You said I was confusing people, but I just didn't want anyone to get in their head that the CVT had gears, because as you well know, they do not. I'm glad you cleared up any misconceptions and I'm sorry for bantering back and forth with you, but I just wanted to make the info. right, and now it is
Gosh wrote:So this engine/transmission works best at 2400rpm,for gas consumption ?I do pretty much 100% city driving, besides going from a dead stop my car rarely breaks 2k rpm. traffic and lights make it very hard to keep car at such a high rpm without having to break within a few metres. normal speeds for me are 60-80 kms/h, rpms are almost always at 1700ish. so would i get better gas consumption driving faster and harder on the gas pedal ?
I do not know very much about this cvt, so forgive me if i am right out to lunch on this post.
Well, what he's saying is that the engine is very close to it's optimal power at 2400 RPMs (like he said 90% of the torque available). This is a good thing for gas mileage, because it takes less aggressive throttle inputs to keep the car moving (fighting the outside forces trying to slow it down such as wind resistance and friction) on the highway. That's why many of the V6 and V8 cars are at very low RPMs at high speeds, because they have plenty of power to keep it moving, even at a low RPM. For city driving, again, accelerating at 2400 RPMs will get you to speed in a very efficient manner, because it gets you there quickly, but it doesn't use too much fuel. Once you get to speed (say 40 in town) it's better if your car is at a lower RPM, so 1700ish is good for city driving. If it were at a steady 2400 in town, it would actually be worse, because you do not need as much power to keep you moving as you would going 70+
