PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Thu Sep 20, 2007 3:48 pm
so I'm an *** and haven't taken any recent pics... so this one is gonna be for the hardcore people that can read. If thats not good enough... I'll put up pics at a later date.
So I ditched the stock WRX turbo and bolted on a tdo6 20G. BOUYA. I am currently running stock wastegate boost of 7.5psi, because it hasn't been tuned yet.
Yesterday I was working on another car, and needed to make a run to the auto parts store, and didn't have another car besides the 240, so I took that. I go there, the car runs normal, get the parts, and come back out. Crank the car... nothing. Its cranking over, but not starting, and REEEKS like fuel. I keep cranking it and finally it fires over, and blows pretty much raw fuel out the sidepipe. After like 3 seconds (for clearing the cylinders and stuff) it runs normal. Smooth, perfect. I drive it back and pop the hood. Everything looks normal. No vac. leaks, nothing.
Today I got a big shipment of suspension stuff (new balljoints/control arms, inner and outer tie rods, and new sway bar end links), so I went over to put all that stuff on. The car wouldn't start. Once again, it REEKS like fuel. Tried pop starting it, nothing. Cranked until the battery died, wouldn't start. Got my friend to jump me, and I pull the fuel pump fuse, and it started up, and died right out. Put the fuse back in and it started and died. Kept cranking and it started and again blew a ton of fuel out the sidepipe. 2 seconds later, its running fine.
I don't expect anyone to know but... anyone know what is up?
Background info:Rebuilt KA24de (semi-built)rebuilt headaftermarket fuel pressure regulator (fuel pressure is in spec)370cc injectors (getting kindof old)Emanage bluestock MAF (Blow-through setup)idle air control valve hooked up after the MAF, so no problem thereno vaccuum leaks
Modified by PapaSmurf2k3 at 3:49 AM 10/5/2007
