float_6969 wrote:
The s12 CA is an 8 valve motor, so I don't know if it will have all 4 valve reliefs that you will nee.
Is the talk of the turbo a question?
I'm a fan of SDS.
turbo talk is a big big question. its been my counter debate the whole time which one i want to use. Personal peferences of yours? and piston related help would be awesome. I know you got some spare parts we talked about.
TheMAN wrote:speaking from experience... if money is tight, don't do anything for now.... resist the urge
once you dive into a project this big, costs can easily go to a couple of grand, and you'll either end up some something half-baked or an undriveable car
there's no go reason to take advantage of tech school time for your personal projects now because all you need to do is learn diligently what you need to learn there and apply that knowledge later when the time is right to do your motor build
you have to ask yourself, is it worth the risk now for making your car a POS, or is it better to just get it done right?
one thing is for sure, it is always a BAD idea to make your only car a project car
This is some better advice and input ive heard on here yet its not. No disrespect when i say this the only risk of making my car a POS is if i were under qualified. If i didnt have the knowledge skills tools or money to do this i wouldnt. And what says i wouldnt get it done right... Its what i want and what i need. See when you get so use to something you crave more and i guess thats what drives my passion for this beloved CA. Who said i only owned one car. My avatar? yeah this is a nissan website i kept it to nissan. Now if i could skip my guidence counseling meeting and refer to what i questioned....
I need to know if these ca18et pistons would work or if i need to look else where. personal perferences?
Im thinking a t28BB sounds right. any other takers?
fuel injectors? 444cc sounds right
Ive been reading alot on ca16de camshafts for ca18det why would these cams perform well in this engine? Higher lift?
Intercoolers?
I need to look more into sds. do you guys personally tune it by laptop computers?
Would a ca18det ecu have all the same pinouts as the DE? Is swapping ecu's possible
Really i have the rest all set and done locked in my mind. its just these few things above im more curious about
