SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Sun Jul 20, 2003 4:18 am
Another useful thing to do is remove the shifter before you pull the engine, and install the other one.
Cleaning products: simple green, 3m wax and adhesive remover, engine degreaser, and brake cleaner are always nice to have.
Products for catching fluids: A couple of oil containers, my new SR had a full pan of oil and overflowed my only pan. Something to catch coolant, something to catch transmission fluid, something to catch power steering fluid, something to catch clutch fluid (if you remove these two hoses).
Fluids needed for the car: 4 quarts of oil, a couple bottles of 100% coolant, or about 3 bottles of the 50/50 mix, 4 bottles of transmission fluid (though three should cover it), clutch fluid, a couple bottles of power steering fluid (aka Dexron III Auto transmission fluid).
Also it might be a good idea to get new plugs, an oil filter and fuel filter.
Do note this all should come out to about $150, which nobody usually works into their swap budget.
