The start of an sr20 with an evo9 turbo
drifthappy
Car: s14
This has been the project for the last 2 weeks so far. I just rebuilt my sr20 i am using stock bottom end it has a built head. It is a s15 sr w/ s14 5 speed we r making everything ourselfs to fit a evo 8 turbo in there. Its been fun so far. We have a blog with videos and more info on the build Fabthis.com check it out.
keep watching the progress
kouki munster
Car: 97 base 240
If by evo 9 turbo you mean a 20g, then I hate to break it to you but forced performance and a few other places have alread beat you to it by offering a 20g with a t2 flange, so that its all but a bolt on for the sr. Hell I'm running one and eat cars running the 2871r as a snack.
But looks cool can't wat to see some finished pics
drifthappy
Car: s14
Sorry I should have explained more I'm not using a t2 flange I am using the twin scroll. Twin scroll is alot better then a t2 it also will cost me alot less to do this twin scroll then buy a t2 20g and manifold I'm not into cheap a** manifolds. So I am pretty sure this will be the only sr with a twin scroll evo turbo unless someone has seen this before?? Hopefully later down the road I will get a FP green
Modified by drifthappy at 8:10 PM 7/28/2009
kouki munster
Car: 97 base 240
I'm not either, thats why I'm running a tomi manifold, another option is to have the stock manifold extrude(sp?) honed, but for what that cost you're only a few bucks short of buying the tomi manifold.
But either way it should be sweet when its done and the FP green turbo is awesome, spools more like an 18g but makes the power of a 20g plus a little more for good measure.
drifthappy
Car: s14
What ever happens I'm sure it's going to be cool I'll have vids up hopefully soon but I'll have more pics tomm we finished the turbo elbow tonight.
duffman1278
Car: 89 240sx Hatch, the wildcats!
Nice TIG work!! Looks really clean
Dattebayo
There is a guy down here on Boca Chica Key who's got a similar setup, he's having trouble with traction when it spools... lol
kouki munster
Car: 97 base 240
Dattebayo wrote:There is a guy down here on Boca Chica Key who's got a similar setup, he's having trouble with traction when it spools... lol
Me to.
drifthappy
Car: s14
Thank u I'll post some pics up in a hour or so whenever I get home
drifthappy
Car: s14
We modified a aftermarket evo turbo elbow enjoy just alittle more work on it. More info on Fabthis.com
drifthappy
Car: s14
kouki munster
Car: 97 base 240
From the looks of it, me thinks you would have been better off making a top mount manifold for it, but I say this not knowing where the oil feed and drain lines are, or how much trouble it is to clock the turbo.
But It still looks awesome, I can't wait so see some dyno #'s and some vids of it running.
drifthappy
Car: s14
We cant clock the turbo cause the internal wastegate. We did look into doing a top mount but again the wastegate was sticking up crazy a** high lol. Im pretty sure that we will have her started up tomm.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Sweet build!
What are you power goals?
kouki munster
Car: 97 base 240
drifthappy wrote:We cant clock the turbo cause the internal wastegate. We did look into doing a top mount but again the wastegate was sticking up crazy a** high lol. Im pretty sure that we will have her started up tomm.
I knew there had to be a good reason for running it bottom mount.
drifthappy
Car: s14
My power goal idk really we r going to do 26 psi so I have know clue whats going to happen lol. Its time to weld now getting closer to the finish.
more pics on fabthis.com
drifthappy
Car: s14
We should be starting her today ill have a vid up.
drifthappy
Car: s14
This little guy is going on another one of our crazy a** projects.
duffman1278
Man your gonna get a sick sun tan and skin cancer is not cool.
drifthappy
Car: s14
^ lol yea your right^
Yes I will be keeping PS as for the AC I have never had AC in the car so I dont know if the set up will clear everything for AC. Ill have pics up tomm of the intake im not 100% sure how I want to run the intake yet. Im sure that we could have paired the runners but as u were saying the extra piping in return longer runner effect the spool time. I dont think that the runners would be as equal length as they r now if we did pair the runners as well. idk its done now so we wont know till I fab up a different style evo SR manifold. The project is coming closer to being finished.enjoy
Here is my sweet a** relocation bracket
Here is the kit
Here it is all bolted up. It looks clean and lots of room.
Fabthis.com
freakyjason
Car: 1990 240sx
Wow! This looks Great! I cant wait to see the final product and some video! You may have already mentioned it, but what are you doing about internals/hg? 26 psi is a lot.
drifthappy
Car: s14
^ thank u ^ ECU i am running a power fc, the head is built tomei pro cams, bc springs,bc retainers, rocker arm stoppers, all brand new seals, apex HG, acl bearings main, rod, and thrust, new oil pump, new rings, hone, hot tank, deck thats off the top of my end. im using stock rods and pistons. Yes 26 psi is alot lol i want to see some crazyness tho lol
Fabthis.com
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
The manifold is a looker. Tuning on c16?
maryjane
from what ive read on tamparacing hes doing a bottom mout also because of a lower cg. lmfao, not trying to flame but you shoulda just stuck with the w/g would of been up to high
drifthappy
Car: s14
^ I didint have the room to work with, do you read. There is no sense in putting in retard sharp bends to pair the runners, it would be redundant, think. Yep super engineer . That was 1 of many reasons for bottom mount including angle of the wastegate, not having to buy new intercooler piping, dump tube design, not boiling my BMC, etc. Dont worry buddy u should of read more on that TR thread before u try to not flame me. Its just not for CG
Fabthis.com
I ask good questions
Car: 92 240 SXSE Coupe with SR20DET
i like the bc sticker on the welding mask!
drifthappy
Car: s14
^ thank u and thank BC lol ^ im just going to tune it with the new turbo then when i get another job that does not lay me off ill retune for c16 might convert to e85
Fabthis.com
