The SR is abou to RUN!!!
Spegt
well, if some of you might or might not know I fully built a SR20det motor. It was on display at the Carlisle Car Show(just the block) I was kind of nervous as is was the first SR that I have built. Here is a rundown
Bored .020 overEagle RodsWeisco ceramic coated pistonsZex springs262(4?) HKS cams3 angle valve job.bigger oil pump assembly
Well I am very nervous on it starting and doing the proposed 600-700hp.But no longer!!!We filled her up with oil tonight and tried to prime her, we wernt getting it pumping right. We just hooked up the starter and turned and turned and turned. We couldnt get it pumping so we went ahead an did some compression testing. 1- 1602- 1903- 1904- 190After a little bit of oil in #1 she went right up to 190 with the rest. Now I am happy and and now sleep a bit safer,... the beast will either go or blow tomarrow at aprox. 7pm.....
forksquared
Car: 91 Nissan 240SX coupe
98 Subaru Forester S (New DD)
i think i saw your block there. i was there with a bunch of friends. and a pregnant girl haha
Spegt
sweet, it was at the Applied Force booth. Good to see that someone noticed thanks!
sr20-thoj
Car: 89 nissan 240sx coupe
Spegt wrote:well, if some of you might or might not know I fully built a SR20det motor. It was on display at the Carlisle Car Show(just the block) I was kind of nervous as is was the first SR that I have built. Here is a rundown
what do you mean by after a little bit of oil in #1?? did you put like a table spoon of oil into cylinder #1 through the spark plug hole??
TonKpilS14
Car: S14 Silvia
im building my SR right now 2, let me know if that **** starts...
Spegt
tablespoon.... not even, and yes through the spark plug hole( dont really know how else I would haha)
And it LIVES>>..!!!!!!!!!! ahahahahah vroom vroom zoom zoom
Once it turned the oil pressure came right up
there is no turbo or piping...but it starts then stop then starts then stops
the longest we had it running was about 30-45 seconds(twice)
The 1200cc injectors I think are making run too rich and killing the motor. We acutally sold the t28 for a bigger T3 or T4 dont know yet. Oh yea and it is contolled by Apexi FC. At least nothing fell apart or broke hahaha
highmilehatch
Spegt wrote:there is no turbo or piping...but it starts then stop then starts then stops
I really don't think that's normal. You should probably figure out why it's doing that.
Spegt wrote:The 1200cc injectors I think are making run too rich and killing the motor. We acutally sold the t28 for a bigger T3 or T4 dont know yet. Oh yea and it is contolled by Apexi FC. At least nothing fell apart or broke hahaha
It really sounds like you have no idea what you are doing. I wouldn't be surprised if you wash down the cylinder walls with too much fuel, contaminate the oil, and spin a bearing. I really hope you mean A'pexi Power FC and not AFC.
Also, you do realize that by pouring oil down a cylinder and watching the compression shoot up is not a good thing right? Especially on a freshly built engine? The ring is obviously not sealing against the cyilnder wall.
Spegt
actually it would be called a wet compression test...and there was not enough oil to fully seal the rings so the rings are sealing properly...and it is FC..the stand alone...umm yea. SR have been ran without a turbo before soo maybe you should read a bit more, not bashing just informing
plus the start up was mostly just to get oil pressure through the system
highmilehatch
The fact that you registered 190 in three cylinders and 160 in another is not good. By pouring the oil in the cylinder, your helping the ring seal against the wall. That shouldn't happen with a fresh engine. Just informing.
Spegt
yes, agreed I do feel that there migth have been a problem, but I am going on the assumption that a ring was just stuck, and the little bit of oil helped it free up and seal the rest of the way....i will check it later and see if it went down at all.
TonKpilS14
Car: S14 Silvia
take some pictures of your car let me check it
