The SOHC rebuild kit is here!
Chris@AMS
Car: 91 Nissan 240sx
I finally got some time to put together a SOHC rebuild kit together. You can see it at the link posted below. Here are some quick details:
Arias .020 over Pistons with 8.8:1 Compression RatioAMS/Turbo240 Connecting RodsClevite Main and Rod BearingsFel-pro Full Engine Gasket Set, Including headgasketArp Main StudsArp Head StudsAll the Necessary Timing Assembly Replacement Parts
http://www.amsperformance.com/...d=304
questions, comments, criticisms appreciated!
ThanksChris
Modified by Chris@AMS at 12:54 PM 6/27/2006
Import_Ant
Finally! Are the timing components OEM Nissan or another brand?
Is it optional to order the kit w/o the Felpro head gasket or is everything set in stone?
Chris@AMS
Import_Ant wrote:Finally! Are the timing components OEM Nissan or another brand?
The timing components are OEM Nissan Parts!The fel-pro gasket is included is included in the fel-pro gasket set as we order it, I wont be able to separate it. Is there a better head gasket that is offered for the SOHC? I can't seem to find any aftermarket HG's but I would like to offer one.
Thanks!Chris
Import_Ant
I planned on using the cometic head gasket from the DOHC KA and trimming off the the front timing cover portion and using an OEM section I have lying around. I know the Cometic unit doesnt come as a complete gasket set though, just as a headgasket by itself but the last time I priced the Fel-Pro SOHC gasket set it was $84 at the local Advance auto parts and a new cometic unit runs $80 for the 90mm bore MLS unit from this site -> Link so would it be feasable as an exchange? Im not sure what the retail on either of those parts would be for you.
It's good to know the timing components are OEM Nissan units though. I didn't notice an oil pump on the list, is that included or not? You can use one from an 81-83 L28ET (280z turbo) as a bolt on upgrade as it moves slightly more volume (good if you have an oil cooler and turbo demanding more flow)
S13FX
Car: '69 l20b Dimeski :)
Hey Chris Im sorry this is off topic but would you guys by any chance have a mani with a T3 flange and a 35mm wastegate flange? some where in the shop for a really reasonable price that you could sell me brother? If so I can pick it up asap. The one I ordered is on back order again for another 3 weeks and I can not wait that long. SOHC of course.
Thanks man.
12valveturbo
Car: s13
The oem head gasket is better.
Chris@AMS
Import_Ant wrote:I planned on using the cometic head gasket from the DOHC KA and trimming off the the front timing cover portion and using an OEM section I have lying around. I know the Cometic unit doesnt come as a complete gasket set though, just as a headgasket by itself but the last time I priced the Fel-Pro SOHC gasket set it was $84 at the local Advance auto parts and a new cometic unit runs $80 for the 90mm bore MLS unit from this site -> Link so would it be feasable as an exchange? Im not sure what the retail on either of those parts would be for you.
sorry i can't break up the fel-pro kit.
Quote »It's good to know the timing components are OEM Nissan units though. I didn't notice an oil pump on the list, is that included or not? You can use one from an 81-83 L28ET (280z turbo) as a bolt on upgrade as it moves slightly more volume (good if you have an oil cooler and turbo demanding more flow)
[/quote]There is no oil pump included in the kit, i will be working on that in the near future as well.
Chris@AMS
S13FX wrote:Hey Chris Im sorry this is off topic but would you guys by any chance have a mani with a T3 flange and a 35mm wastegate flange? some where in the shop for a really reasonable price that you could sell me brother? If so I can pick it up asap. The one I ordered is on back order again for another 3 weeks and I can not wait that long. SOHC of course.
Thanks man.
I do not have an manifold at all right now, we are currently working on one for a DOHC motor. We will take a look at the SOHC motor shortly after we are done with the other. sorry!
Chris@AMS
12valveturbo wrote:The oem head gasket is better.
thanks!
Import_Ant
Chris@AMS wrote:sorry i can't break up the fel-pro kit.
I meant the Cometic head gasket instead of the entire felpro kit since the two are roughly the same price. Sorry if I worded that poorly.
Chris@AMS
I'll tell you what I can do for you. I will match the price from the Import performance parts place. I wouldnt want you to have to order from them...
12valveturbo
Car: s13
Honestly by the time you buy all the other gaskets separately it will cost more than getting this kit and buying the cometic.
Import_Ant
Thanks for the reply Chris, I'm hoping to get one of my fastbacks sold soon to fund this I'll keep in touch with you and hopefully we can make this happen soon.
12valveturbo wrote:Honestly by the time you buy all the other gaskets separately it will cost more than getting this kit and buying the cometic.
you're telling me a valve cover gasket, throttle body gasket, intake and exhaust manifold gaskets, valve stem seals, and coolant inlet flange gasket come to 80$?
The bulk of the cost of the felpro set IS the headgasket.
12valveturbo
Car: s13
plus timing cover set and oil pan. It might not cost more im just saying that stuff will add up.
Modified by 12valveturbo at 10:39 AM 6/28/2006
Florida240sx
I never use oil pan gasket. Just gasket maker.
Import_Ant
12valveturbo wrote:plus timing cover set and oil pan. It might not cost more im just saying that stuff will add up.
here's what the Felpro set comes with, those items are NOT included. Felpro DOES sell a cork oil pan gasket but there isn't one for the timing cover that I am aware of, I had to make my own using McKanica silver.
I have rebuilt 2 SOHC KAs so far with Felpro kits. They are definitely good quality for a daily driver and I will use them again I just am going to use a cometic HG for my strip car, it's all a matter of personal preference.
12valveturbo
Car: s13
Thats cool.They do sell a timing cover set its more or less rtv and the two seals. I thought he was talking about the rebuild kit not the hs9646pt.
SSS
Chris,
Is the DE oil pump kit OEM nissan or an aftermarket supplier?
Also, FYI the SOHC fwd u12's use this oil pump in the timing case.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Fel pro SOHC headgasket from autozone is $31 WTF are you smoking?
$80 pft...
http://autozone.com/servlet/Ui...C%7EW <-- link.. might not work but whatever..
Import_Ant
Kenrik wrote:Fel pro SOHC headgasket from autozone is $31 WTF are you smoking?
you're comparing apples to oranges. Fel Pro gasket SET not the head gasket by itself...
Chris@AMS
SSS wrote:Chris,
the de oil pump kit is all nissan OEM parts.
thankschris
