kapower06 »
https://forums.nicoclub.com/kapower06-u18983.html
Thu Jun 15, 2006 6:11 am
Mine used to smell like raw fuel when I turned the heater on , I had to find out what it was cause it was january here ( about 15-30deg average) Well I traced it down to a slight exhaust leak between the turbo and the 02 housing, I guess the exhaust went up the firewall and into the cowl which go sucked into the interior. But just an idea,
Does it just smell at a low speed or at idle? Have you changed your plugs lately? Your 02 sensor new or old, and is it hooked up correctly? also have you ever cleaned off or replaced your H2o temp sensor?
